Just a basic matrix multiplication error. Confused in using range of variables
  • September 23, 2017
  • 2 replies
  • 3719 views
11.jpgwhen i am using r=1 , it works good ( value of Vs) but i want to calculate for the range of values from 1 to 10. I already tried using in matrix form and semi colon form but still it is giving me error. Please help somebody22.jpg33.jpg
Best answer by ValeryOchkov
May by this help you
You cannot confuse a range variable with a single column vector.  One can be indexed into (the vector) one cannot (the range variable).  In Mathcad 14/15 these used to be displayed differently.  In Prime they are not.
Prime 4.0 enclosed with a pdf  .
I'm afraid you're confused.
You cannot see the difference between a range variable and a vector variable, unless you've chosen to use different tags for them.The difference will become apparent upon indexing the variable and evaluating it:
In Prime the options of tagging (labelling) variables are more limited than they used to be in Mathcad.
On the other hand, the difference between an index and a literal subscript is apparent in Prime upon selecting the expression. A grey [ is shown next to an index then.
