Lag times and differential equations
martin_m-disabl
Dear all,
in 2005 I received excellent support in this forum, that resulted in the attached mathcad 11-file (see "Lag times and differential equations" posted on 6/27/2005). As this version of mathcad is no longer available for me, I tried to use the file in Mathcad 14. But at the stage of the minerr-calculation I receive the error message that the variable is not defined. I invested some time to solve the problem, but without success.
Could you please help me to use the file in Mathcad 14?
Thanks a million in advance
Martin
If you type k[31= or t[0= after your Green definitions they are =undefined.
Re-typing them defines them. Weird!
Thanks a lot for the quick response.
I have redefined the variables, but was not successful. What ever I do I receive for the minerr function the message "variable not defined".
Any suggestion?
Martin
You're just confusing literal subscripts and array subscripts. The green definitions are all literal subscripts, the corresponding array subscript expressions are undefined.
__________________
� � � � Tom Gutman
I have accordingly adapted the given block and now it works.
Thanks a million
Martin
