Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Take a Ver 11 program that uses Levenburg Marquardt, and initializes all optimization parameters with real numbers. Convert the program to V14. Run it in 14. It answers with complex results in the optimized parameters. This is a bug, I think...or is there a new way to control the optimization results?
