This question is regarding iteration with two simultaneous criteria.
I've been able to solve this with relatively simple manner (in the beginning of file), but I believe that this problem could be solved also with "while" operator (tries at the end of file), which could be then modified to solve a more complex problems.
Thank you for your help.
Pretty fast work
Thank you.
Pretty fast work
Thank you.
No problem at all. You caught me on my dinner ![]()
Mike,
Corrected a couple of things and added a simpler way to get the y1
Nicely done Wayne,
Very lazy of me I know, but I was on my dinner. I'll have a go later if I find the energy ![]()
Mike
