MC15: Solving an ODE
MoeSzyslak
All --
I don't have much experience solving ODEs in Mathcad, Any ideas why this doesn't work?
FWIW, I know I can separate variable and just put the necessary equations inside of a solve block and Minerr it, but that produces its own set of problems, so I would like to try this. Obviously, the symbolic engine chokes on the integral, so we can't do it directly.
Thanks in advance.
Matt
(To:MoeSzyslak)
Moe Szyslak wrote:
Thanks for the tip, but even after I remove units, I get the same, largely unhelpful, error message: "Cannot understand this syntax".
Change LHS with RHS of the equation - Mathcad 15 likes the derivatives on the LHS. No comment.
5 REPLIES 5
(To:MoeSzyslak)
Odesolve doesn't work with units (yes, thats one advantage of Prime) so try without.
(To:MoeSzyslak)
LucMeekes
(To:MoeSzyslak)
Is this of any help? (Mathcad 11)
All -- thanks a ton. Removing units AND bringing the derivative over the the LHS of the equation did the trick, as Werner showed. I am even able to solve the more general problem (i.e., with an integral premultiplier that has h in it's limits) after this modification (though only for a very limited parameter space).
Thanks again for the help.
