MCAD 14 M020 Compatibility
WayneQuernemoen
I've been told that MCAD 14 M020 is not compatible with Windows XP Pro SP3, and have found to my chagrin that it is true! Does anybody know if there is or might be an existent or future release Of MCAD 14 or of Microsoft SPs that will allow MCAD 14 to be compatible with the operating system?
MCAD 14 M020 is compatible with Windows XP Pro SP3. Where did you hear that it isn't?
Richard
On 8/23/2009 4:05:27 PM, WayneQ wrote:
>and have
>true!
What was it that didn't work?
There are a few regular repeating (occasional)
faults with all the recent versions/releases,
which can catch the unwary.
I had a problem with the temporary cache file.
Once it is deleted everything recovers fine.
It was made worse for me because I was doing a
remote test using a common roaming profile, so I
was in two places at once and couldn't delete the
problem file in the normal manner!
Philip Oakley
