MEP - Add ability to minimize the vertical or horizontal spacing between regions
StuartBruff
23-Emerald V
Mathcad Enhancement Proposal (MEP):  Extend the Document Spacing functionality to minimise the vertical or horizontal spacing between regions
The "Separate Regions" functionality is a useful tool for organising a Mathcad worksheet.  However, quite often I find myself "wasting" time doing the opposite - removing spacing between regions.
The usual scenario is that I write partial functions and/or evaluate them as I develop the final form of a function or set of functions.
When I've got the function in its final form, I delete the regions that are no longer required, which leaves me with the task of closing up the gaps their deletion leaves.  This is the kind of mindless activity best left to automation.
An additional button in the Document Spacing group to minimise region spacing, either horizontally or vertically, would be a useful asset to aid in this and other use cases.
Additional MEP:
MEP - Auto-increment spacing between regions when pressing the Separate Regions if the selected regions already have uniform spacing.
A common scenario for this is adding space for function documentation.
Stuart
0 REPLIES 0
