Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Mathcad 14 regions should import as math expressions into Mathcad Prime 1.0, unless they are a feature that is not implemented, such as symbolics. Then they import as an image, so the information is not lost.
Can you see what it is in the math region? If it's unexpected, then send the file to -.
