I installed MC5.0 and tryed to start the F1 Help Button, but there is no Help dokumentation available.
How can I fix this?
Windows 10-64Bit
Java is updated
Thank you for your help
Volker
Not sure why you don't see the help pages.
In Prime 5 there seems to be no local help. Help is only available online.
If you press F1, your default browser should open, connect to support.ptc.com and show the appropriate page.
Start page of the help is
https://support.ptc.com/help/mathcad/en/index.html#page/PTC_Mathcad_Help
So if you have a browser set up working OK and a working internet connection, you should see the help.
You may try a reinstall of P5 or contact PTC support.
Surely you jest!
Using the browser to read local files is enough, but no local files? Wow!!
@Fred_Kohlhepp wrote:
Surely you jest!
Not me, its PTCs special sense of humor.
The default is to not install it locally, but it should be an option during installation.
does that mean they download the files to your computer but don't use them unless you tell them to?
Memory hogs!!
Memory hogs!!
No in standard installation the help files are not unpacked locally and are only available online.
If you chose at installation time to unpack the help files locally, the browser is pointed to the locally saved files of course.
I don't like the behaviour of having online help as default option - it should be the other way round and clearly stated at installation time that you can save about 75 MB of disk space per language (the help is available in 10 languages) if you chose to use online help.
Given nowadays storage size this minimal save of space sure does not justify the hassles of online help files.
Only reason for online help could be better timeliness. But there is no reason why locally stored help files shouldn't be automatically updated as need, too, and given the development speed of Prime this is very unlikely anyway.
Yes, I can confirm the documentation is correct. I had not noticed that option when I installed the software.
There is no option to change the installation later and add the help files- you'll have to start the Prime 5 setup anew to install the help files locally.
