Hey guys, I'm having problems with mathcad loading up properly.
for some reason my MathCad started not wanting to load up, but when I would go to my event viewer it doesn't load properly.
The Faulting module name: KERNELBASE.dll, version: 6.1.7600.16385
Exception code: 0xe06d7363
Fault offset: 0x0000b727
Faulting process: 0x18d8
Faulting appllication path: C:\Program Files (x86)\Mathcad\Mathcad 14\mathcad.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
from what it looks like from this error it seems like the installation isn't the problem but it may be an operating system problem.
How could i go about fixing this issue? Reloading the operating system?
I have the same problem witn WIN 7 (32bit) on my new HP8540p Laptop.
MC 15 (German witn M005) crashes when I start it and the eventlog shows that Kernelbase.dll is to blame.
Have you an idea what to do?
Walter
I too have problem with kernal while setting up Creo 2 as it says
| Fault Module Name: | KERNELBASE.dll |
I have the same problem with Prime2, I have formated my HD and reinstaled Prime2, The kernelbase problem is still not resolved.
Had the same issue.
You need to download msxml 4.0 sp3:
http://www.microsoft.com/en-us/download/details.aspx?id=15697
After installing the error was gone and mathlab started.
Solution was found after reading the installation guide I stumbled on while looking for updates.
Hope this solves it for you as well.
Jeroen
