Hi, I just downloaded it. The readme.pdf file contains a "what's new" section for M030, though not M035. Can't say what the last cycle, did, but M030 made improvements with respect to Windchill WGM support, new installation options, and the following bug fixes: SPR 1436139. Addresses specific problems involving rapid consumption of memory upon repeated recalculation of a worksheet. SPR 1502717. Fixes improper result returned when evaluating 2^31. SPR 1507803. Addresses a specific memory leak issue relating to an uninitialized handle. SPR 1507032. Addresses a compatibility problem resulting from an improvement in how numeric tolerance in integrals was inferred. 1547641 Fixes PDF file generation problem on Window XP x64 machines. 1437427 Fixes in-line evaluation to update display to match available value. 1587915. Addresses a WRITEPRN restriction by increasing the maximum allowable string length from 128 to 1024. 1403321 Addresses specific memory release issue involving large worksheet computations.
