Hi ,
When Converting Mathcad-15 ".XMCD" file to Mathcad Prime 9.0.0.0, text box controls using VBA are not properly converted in the Mathcad Prime file, kindly provide the solution for covert the Mathcad-15 textbox controlled by VBA script to MATHCAD prime.
Thank you.
discuss your problem with PTC Support. These pages belong to PTC User Community.
try Mathcad prime 10. I had a few successful conversions of Mathcad 15 textboxes to Mathcad Prime 10 textboxes.
Good luck
raiko
Thanks for the response, let me check With Mathcad Prime-10.
I have tried with Math cad-10 Prime version, still the text box control was not converted properly, here I am attached both Mathcad-15 version file and Mathcad-Prime-10 version file, please help me to proper conversion.
Thank You.
it's a Prime issue. The input is rather non-intuitive. You have to use a matrix if you need multiple inputs. I have used a transposed matrix as input in order to save space. Example is attached
Cheers
Its Working, Thank you so much Raiko.
Cheers.👍
