Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Do you know that in 2011 we have the 25-jubilee of Mathcad!? Now we must think about it! Prepare it! Can You edit this picture? Val (mathcad user since 1989) http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
