Mathcad Prime 4.0 Integration problem and Plotting Problem NEED HELP ASAP ( File attached )
  • December 9, 2018
  • 5191 views
Hey Guys,
I have a problem in Mathcad Prime 4.0 related to Integration problem and Plotting Problem NEED HELP ASAP Please ( File attached )
Best answer by Werner_E
Just noticed that you wrote that you are using Prime 4 and so you would not be able to read my file.
Unfortunately to convert the sheet from P5 to P4 I would have to copy every single region from the P5 sheet to a newly created P4 sheet, which is something I refuse to do.
I remember that Luc a while ago wrote that it would be possible to put all regions in an area and copy the whole collapsed area to a P4 sheet. I gave it a try but unfortunately it did not work at all.
So all I can do at the moment is provide a pdf printout of the file I posted.
There are several problems in your sheet.
Solve the problems, then come back if needed.
Thank you so much, the graph has been solved but for the integration it doesn't want to be solved.
This mixture of vectors and functions is quite a mess and you seem to have confused yourself with it.
I would strongly suggest setting up all calculations as functions of omega and getting rid of any vectors completely.
After all this is math program and not a spreadsheet!
See the attached Prime 5 file how this could be done.
