Mathcad Prime 5.0: Plotting failed. Replace complex values and NaNs by real numbers.
saadhere
Greetings,
I am working on this task where I need to plot a variable against time. However, I am getting an error saying "Plotting failed. replace complex values and NaNs by real numbers". Can someone help me sort this out?
You need to assign your "time" range in seconds - you're trying to compare a unit-less value against values with units of time.
