Mathcad Prime 7 plot missing features after conversion from Mathcad 15
PabloGarcia
7-Bedrock
After conversion of a Mathcad 15 worksheet, the plot was missing plot title, axes labels, and gridlines (see the attachment).
Is there any way to obtain on Prime an "engineering looking plot" as in the original Mathcad plot instead of the converted "high school" plot stripped of the original features.
I would be grateful for any pointers.
ttokoro
20-Turquoise
(To:PabloGarcia)
At least, you can add grid lines by using grid function made by Luc and other members. You can add text block by superimpose, however, add text in plot is very hard.
7 REPLIES 7
Try the chart component.  It has axis labels, graph titles, and grids, See Math tab | Regions group |  Chart component
If you upload your worksheet someone can show you how to use the chart component
Cheers
Terry
ttokoro
20-Turquoise
(To:PabloGarcia)
Thank you ttokoro for the plots and worksheet. That looks better and it is alright I suppose as a workaround in the interim until PTC produces a seamless converter.
However, I am still in disbelief (short of saying livid) that simple features of a plot such as title, axes labels and formats cannot be converted from Mathcad 15 (MC15) to Prime 7 (MP7) without manual intervention.  I have well over 300 worksheets in MC15 that I haven't yet converted because I seem to require editing most converted worksheets which is very time consuming, so I end up using my legacy MC15 version by default instead. I have attached as an example the original worksheet in MC15 format and the resulting MP7 after conversion.
ttokoro
20-Turquoise
(To:PabloGarcia)
Resulting MP7 after conversion + grid + text box.
ttokoro,
The final result looks good. Having to resort to editing the number of worksheets that I have in my library after conversion remains a pain (at least for me).
Many thanks for showing the output and corresponding features that need to be applied. I will try it on my own.
By the way, I tried to open your converted worksheet it is not MP7, I get the error message that it is in a newer version of Mathcad Prime, I assume MP8.
ttokoro
20-Turquoise
(To:PabloGarcia)
Sorry it is Prime 8. Only expert member can down convert to Prime 7.
You don't have to be an expert, simply follow the steps given here : https://community.ptc.com/t5/Mathcad/Prime-backwards-compatibility-solved-Or-at-least-hacked/m-p/637537/highlight/true#M188056
Attached is the file "converted" to P6 format which P7 should be able to open.
The position of your plot over plot seems to have been changed, though
I guess you used this strange method of putting one plot over the other superimposing them by eye to avoid that the axis expressions for the grids are shown, but I guess it would be better to use just one plot, even if it will either show none ar all three axis expressions.
