Mathcad Prime Giving Wrong Answers
polarnaut
When I use the equals sign at the end of the equation to show the answer, sometimes if I alter the equation, the answer doesn't get updated leaving a wrong answer which gets carried through all of the calculations. See the attached PDF as an example. 0.94 + .74 = 1.68, not 1.59 as shown. Is there a fix for this? Note: This doesn't seem to be a problem when the results are shown seperately in another math region.
6 REPLIES 6
Hello!
Could you upload your Mathcad file (.mcdx)?
Simply assigning numbers (with units) to variables I cannot recreate the problem.
Joeboy
(To:Fred_Kohlhepp)
I use Mathcad 14 and this is a common problem
Joeboy
(To:polarnaut)
In the attached file go to the comment in red, in the line below change d, initially the value of ne would not change, other values did. Once I saved the file and reopened it ne was evaluated properly. The problem does not occur in any consistent fashion. When I use the = evaluation at the end of an expression I reevalaute it if I change inputs.
VladimirN
(To:Joeboy)
I have changed value for "d" on d=0,7 [m] in two places in document Mathcad and in both cases value for "ne" became equal ne=0.035 [s/m^0.333].
The given changes spent in Mathcad 15.
Fred_Kohlhepp
23-Emerald I
(To:Joeboy)
I can't get my Mathcad 14 to replicate your discrepancy.
Another matter; It's very bad form to copy and paste equations further down in a work sheet to change a variable; much cleaner to use functions.
I've changed part of your work sheet to define functions to demonstrate what I mean.
