I wanted to create a table with text and numbers and then be able to sum the numbers. Such as:
Item Wt
Motor 100
Bearing 20
Mount 220
TotalWeight:= Sum Wt
But it is complaining that "Motor" etc. are undefined variables.
I could created just a single column table to hold the weights and then align it against a series of text boxes but that does not feel right.
Thanks for your help,
Robin
It's best if you attach your file and/or include a snapshot.
You likely just need to put Motor, Bearing, & Mount in quotes:
Item Wt
"Motor" 100
"Bearing" 20
"Mount" 220
Thanks, That works for me.
Robin
