Mathcad paradox: lb:=lb - en error, lb:=kg - all is OK!
See attached files - Mathcad 15 and Mathcad Prime!
Roundoff.
Got to be careful making comparisons of floating point numbers when your worksheet options are set to "Use exact equality for comparisons and truncation" ![]()
Roundoff.
Richard Jackson wrote:
Roundoff.
Thanks Richard, I knew it.
But the paradox is a paradox.
Life (Mathcad) would be uninteresting without paradoxes.
I think I recall something like this coming up on the forums once before. Mathcad can be a little deceptive when using units, because although you may enter the numerical part of a quantity as "1" (e.g. 1 lb), which has an exact binary representation, it is not necessarily stored internally as "1".
