Mathcad prime 5.0
BB1
Mathcad prime 5.0
I wanted to create the Y BUS matrix from Netlist and solve that to get currents and voltages of each node.
For this i need to know how to solve the AX=B in matrix format, if all matrices(A,X and B) having variables only,
I want X in terms of Varibales(eqn)
Please check the 29th page of this pdf:
http://www3.imperial.ac.uk/pls/portallive/docs/1/7292571.PDF
(To:BB1)
You may possibly be able to do what you are looking for, but as long as an expression contains an unknown/undefined variable you obviously can't evaluate that expression or function numerically (that means using the normal =).
13 REPLIES 13
terryhendicott
(To:BB1)
you just use:-
Terry
terryhendicott
(To:BB1)
I will try this post again to get the graphic:
You just use:-
Cheers
Terry
BB1
(To:terryhendicott)
Please check the attachment, that one i am not able to solve
terryhendicott
(To:BB1)
The inverse of a matrix times the matrix is the identity matrix (all zeros except diagonals being one)
Cheers Terry
BB1
(To:terryhendicott)
Please check attachment.
why the same inverse is not working in program?, but outside its working fine,
terryhendicott
(To:BB1)
Symbolic outside of the program does not need x and y to be defined to work.
Numeric inside the program needs x and y defined as numerical values to calculate the inverse.
Cheers
Terry
(To:BB1)
It will work OK inside a program. too, but only if you evaluate the program symbolically, not numerically.
See here: https://community.ptc.com/t5/PTC-Mathcad/Mathcad-prime-5-0-matrix-multiplication/m-p/585721/highlight/true#M183830
(To:BB1)
Do you really need a general symbolic solution? It looks a bit uncomfortable:
Wouldn't do a numerical solution do the job good enough?
You may either use the matrix approach or a solve block with the original node equations.
BB1
(To:Werner_E)
I need the solution in symbolically..means interms of variables like in X,y
BB1
(To:Werner_E)
Thanks for your answer, please check the attachment.
The first two are giving properly and last one is not solving, am i missing anything or it cant solve??.
I need the answer for last one in program, Nett(FF).
Thanks In advance.
(To:BB1)
Always post the worksheet, not just pictures!
Why don't you just define Nett(B):=B^-1
Guess you don't need a global definition
Then you could use Nett(FF)->
As long as FF contains unknown variables you cannot evaluate your function Nett numerically.
BB1
(To:Werner_E)
As you said I can do, but the thing is my matrix will have only variable
and need to get some required data from that matrix using programming,
after that I need to form one matrix out of the main matrix, that matrix
also in variables only and finally need to do inverse of the matrix which I
formed from the main Matrix.
Everything it should solve symbolically,
Thanks for your patience...
(To:BB1)
