mycode : var m = new ActiveXObject("Mathcad.MatrixValue");
when i create matrixvalue object in the up way ,in the IE it pass ;but in the pro/E IE ,it is created failed , and have javascript error,
the error message :
the Activex can not create "Mathcad.MatrixValue" object;
thanks
Where is PTC expert? Who can help me?
Thanks!
Try to contact with PTC's technical support by creating a new "Case", here: http://www.ptc.com/appserver/cs/case/case_logger.jsp or by using "Mathcad Installation & Licensing Support Center":
http://www.ptc.com/support/mathcad_supportCenter.htm
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
