Matrix input to draw a shape
SFares
in the attached sheet, please scroll down the the blue arrow. when i key in the values insdie the matrix, it draws the sketch and does the calculation. Howerver when i have some of these values inside matrix calculated to save myself from inputing them, i get an error message. Not sure why. Thanks!
6 REPLIES 6
(To:SFares)
Don't use global assignments!
While I do not recommend using global definitions I have change the few definitions you had within your worksheet to global definitions.
... and added the missing units.
Nevertheless IMHO changing the global assignments to normal ones would be the better way.
Yes and adding the missing units.
Too lazy to go that way
Won't see it as our job to do so anyway. 😉
It's sure not. Well at least it has been pointed out.
