Good morning.
I have a function with the variable working into a closed interval; I'd like to find the MEAN value. Using the function MEAN, this function is getting out the save values of the function.
How could I do?
@Andrea4505htown wrote:
Good morning.
How could I do?
The function mean works on vectors.
Integrate the function over the entire interval, and divide by the length of the interval.
Good morning.
How could I do?
See please! If you can not use a range variable - do not us it!
You missed a pi
Valery, it is interesting.
Could you send me the code that you did?
I'm pretty new with Mathcad and I'd like to understand the code that you have written.
And this is the answer.
