Minimize a function on mathcad prime 3.1
bmohamed
Hello guys,
I want to minimize a function, i use to method of minimizing without any result i have one error msg for each one
The second methode is using bloc resolution:
but also i have an error that my entry must be a matrix.
File attached.
Please a need a help.
(To:bmohamed)
Guess you also have to turn Mt into a function of OD,ID and H.
13 REPLIES 13
See one example
Thank you for your answer
i define Mt like a fonction, I don't understand how he don't considere it like a function ?
And even if i remove the Mt from the "Minimize" function a still have the problem with CTOL and TOL.
RichardJ
(To:bmohamed)
Why do you think that's a function definition? Mt has no arguments. You need this:
(To:bmohamed)
Cant read your file at the moment, but from Valerys screenshot I see that you don't have a function Mt to minimize. Mt looks like a 1x1 matrix (why?).
You may give "minerr" a try instead of "minimize".
Mt it's not a matrix i defined it like
and i tried with Minerr but the problem don't change they told me that i have a problem with the value of H " that may be a scalar or matrix) the probleme is always the same when i use a solve box
RichardJ
(To:bmohamed)
It's a matrix because of this:
You inserted "square brackets" by using the matrix tool. They are not just cosmetic. If you retype it correctly you should have
RichardJ
(To:bmohamed)
In your first inequality you have Bmax as a function on the left, and a variable on the right. It is actually possible to do that, but you have to set the labels differently for the function and the variable. The way you have it now, your function definition overwrote your variable definition. Even though you could have Bmax as both a function and a variable, I would consider that very bad practice, because you are relying on only the formatting of a font (italic vs upright) to distinguish the two.
that was a good point about Mt, "square brackets" and about Bmax.
I rectify the three mistakes but stil have problem with TOL and CTOL.
So the problem still here :'
RichardJ
(To:RichardJ)
Evidently the variable should be B_max, not Bmax. With that and the other fixes, it works.
I fixed it but still have the problem
and i can't open your fill they told that use they version that i don't have !
i have MC prime 3.1
(To:bmohamed)
RichardJ
(To:bmohamed)
i have MC prime 3.1
Unfortunately, I have 3.0 and 4.0, but not 3.1. 3.0 cannot read your file, and 4.0 cannot save in a format you can read! A completely ridiculous situation.
Werner Exinger‌ gave me a correct answers with a version that i have.
Richard Jackson‌ Yeah it's a real rediculous one
Thank you guys for all, that was a big help for me :
Well done my saviors
