Is it possible to use the minimum function to create a vector of the minimum line-by-line between of two or more vectors?
Edited to include Mathcad 15 version
In MC15 there are three different summation operators. You had the one for range variable summation. I replaced it with the one for vector summation.
I just noticed that there was a slight error in that worksheet:
You say "Use solve block to find c", but you find x, Fs, and C. But x is not defined and appears nowhere in your equations. You also have a summation with an empty placeholder (you can do that in Prime, not in Mathcad 15). If you get rid of x and the summation you get a solution:
Thank you Richard, that x was meant to be a c. In your reply, how did you get the complete vectors to display and not vectors shown as their size: {2,1}?
OK. What was the summation supposed to be?
Put the cursor in the result, select "Format", "Result", "Display Options", and check "Expand nested arrays".
Thank you Richard. The idea behind the solve block is to determine what c is. The summation of Fs is because there are multiple Fs values (d is a vector) and C has one valve. Both Fs and C depend on c. All the Fs and C values should add to zero and this should allow the solve block to find c. Because a summation can't be used, is there another way to do this?
Can this be done with one single c value and 2+ valves for Fs? I was able to get this to work in Prime with one valve for c and three values of Fs using the summation function but I was unable to get the min function in Fs to work. If one value is c is needed maybe this will only work in Prime?
If it works in Prime, it can be made to work n MC15, but I suspect you are not seeing what you think you are seeing in Prime. For scalar As and d you have three equations, therefore you must solve for three unknowns. When you make A.s and d two element vectors then you have 6 equations, and you must solve for six unknowns. If you restrict c to be the same for both values of As and d then you have only 5 unknowns, and in general there will be no solution. This is true regardless of what math software (or pencil and paper) you use to try and solve the equations.
The values for A.s and d are known. The only unknown valve is c.
F.s utilizes c in its definition and C also utilizes c in its definitions. The summation of F.s added to C equals 0 is the equation that relates the two. My goal is to enter this as one equation (F.s+C =0) with one unknown (c). Maybe I've entered this incorrectly.
Thank you Richard. How were you able to remove the black square below the Sigma in the summation of F.s(c)?
It looks like this works Richard. Thank you!
Is there a way to make F.s(c)/A.s divide each value of F.s by the corresponding value in A.s (F.s1/A.s1, F.s2/A.s2, etc.)? In the attached worksheet the values resulting from this division are strangely the same.
When using the min operator in Prime in the Fs(c) statement I get an error that says: "min has multiple definitions, you must specify the label to select the definition that you want". It appears there is no place to "specify a label." You wouldn't know what this error means?
Sure they are the same:
Once you have found c, all the variables on the RHS are fixed, so Fs(c)/As is the same for all pairs of Fs(c) and As
Put your cursor in "min". On the math tab click on "labels" and select "function".
Should the values not be the same because d is different in each case? In the attached the values on the RHS side don't match.
Thank you, your trick for getting "min" in Prime 3.1 works.
