Thanks for your time and help, Tokoro. ![]()
1. Do the first question or second question you answer to ?
2. Is there a way "Making Assumptions About Variables" to eliminate an other solution ?
Best Regards.
Loi Le.
by T.Tokoro.
By the way, N is not limited to Integer, such as N=5/2 has a solution.
I greatly appreciate your time and help, Tokoro.
The Equation is very, very simple, is very, very neat.
( image 4'' )
Many, many thanks again.
Best Regards.
Loi Le.
Following the hint then :
( image 4''' )
Thanks again.
or a similar way :
( image 4'''' )
