Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I'm using it to find the canonical coefficients of a canonical correlation. I can then use these correlation coefficients as part of a descriminant function analysis.
The book I have skims over the calculations because it assumes you just plug the figures into SPSS and get the answer.
Philip ___________________ Nobody can hear you scream in Euclidean space.
