New ode problem (for Alan, Viktor and all):
A steel ball (with d=100 mm and Ro=7800 kg/m^3) was thrown upward. He has reached a certain maximum height (h.max=250 m) and fell to the ground after a certain time (t.end=17s).
What is the initial speed of the ball and what is a value of the coefficient of drag k (F.drag=k S Ro.air v^2). Ro.air=1.225 kg/m^3 or is a function of the height.
See for the start here http://communities.ptc.com/message/187832
Thanks, Alan!
I would like to use the Maximize function but:
PS
Better to have:
Please, Valery. Sorry, without units (MC 14).
Viktor
Thanks and Sorry,
not v(t)^2 but v(t)*|v(t)| or v(t)^2*sign(v(t))
And attach please the file!
What is it with you and throwing balls in the air Valery!!! ![]()
Oh well, attached is my version - in Prime 2, with units.
Alan
Alan, show a picture please. I do not have MC Prime now!
Viktor
Actually, my 'solution' is wrong! I made an incorrect assumption. For some reason I'm unable to edit my earlier post! But I can edit this one!!!
I'll try to generate a correct solution later today, and will post a picture of it as well Viktor.
Alan
Up and down phases are symmetrical only by k=0!
1) How to do it automatically (see the picture, Mathcad 15 and Mathcad Prime files)?
2) Has the problem solution by this initial data?
Here's my automatic answer. Of course the up and down movements are not symmetrical, as I had assumed in my first post, because of the drag! I've not bothered with the Archimedes upthrust as it's a small effect.
Alan
Here are the images, for Viktor:
v0 seems very high!
Thanks, Alan!
PS
Better to have:
Yes, tend = 15s gives smaller v0 and k. The system is very sensitive to tend, and, as it stands fails for tend of 14s or less. Can you determine (automatically) the minimum value of tend for which the program will find a solution?
Alan
We can carry out real experiment - shoot guns or catapults cannon ball straight up and measure the time of flight and maximum lift of the cannon ball!
Ro=f(h)
Ro=f(h)
Expensive method!
In terms of the model, the minimum possible time that doesn't lead to a failure to converge, is when k is zero. This gives a tend of 2.sqrt(2.hmax/g).
Alan
Ro=f(h)
Expensive method!
Alan
But I have in Moscow Kremlin one device for this experiment:
A symbolic solution of the problem (Maple):
a) k=0
b) k>0
