None of my printer options are available in Prime 6.0, is this normal?
This is what I see in Prime 6.0:
These are the drivers on my computer:
I would expect Adobe PDF to show up in Mathcad too. I see this article from PTC "How to create PDF of worksheets from Mathcad and Mathcad Prime", but is that really the only solution? Export to rich text > open in rich text editor > print to PDF cannot be the only workflow (i.e., 3 steps involving 3 different applications every time I want to print to PDF - what!?)
I tried repairing and reinstalling Mathcad and Adobe, but Adobe PDF driver still does not show up as an option. Does anyone know if printing directly to PDF is supported in Prime 6.0, and how to fix it if it is?
Maybe you should slide the bar to the left:
to see the other printers...?
LOL, I had such a good laugh. That was exactly right. ¯\_(ツ)_/¯
Print-to-PDF is as of Prime 7 and on.
1. Try to set the default printer in your system - "Adobe PDF" printer.
2. Install an additional PDF printer, for example: https://www.cutepdf.com/index.htm
