Please see the attached Mathcad 15 file. I am doing incremental solution formulation to trace a nonlinear curve. the only step that i am not sure about is how to plot the incremental solution (blue curve). I appreciate any assistance!
Sam
Thank you so much Luc!
Sam
Hi Luc,
How can I make the first value for P is zero and corresponds to w=0? Right now the first value for P corresponds to w=0 causing an upward shift.
Thank you!
Sam
Like this:
You should note/know that by default, Mathcad starts indexing arrays at 0, not at 1.
Thank you Luc!
Thank You!
Sam
