Hello! This is my problem: I have to solve a second order ordinary differential equation with a set of different values for a parameter, and I would like to avoid to do it manually. I've tried to put the Rkadapt inside a program, but it refuses to accept the vector containing the derivatives (it doesn't recognize the variable t inside D(t,y)), while it seems to accept the vector with initial conditions. Actually, MathCad produces a result if leave D(t,y) OUTSIDE the program, but since my parameter expressing initial conditions is contained also in D(t,y), it gives the solution with a value of the parameter defined above, not with the values defined inside the program (on the contrary it seems to recognize the changing initial conditions defined inside the program). Is there any way to do it? Is there some other way to do it without using programs? Thanks in advance
