Good morning Community:
I have a question about how to operate data from a matrix for a certain identity condition (id), so that a matrix solution can be obtained. Matcad Prime V.8.0 version.
Thanks for your attention.
Translated by the Community Moderation using Google Translate
Buen día Comunidad:
Tengo una duda de como operar datos de una matriz para una determinada condición de identidad (id), de modo que se pueda obtener una solución en matriz. Versión Matcad Prime V.8.0.
Gracias por la atención.
Maybe that way:
BTW, I guess that you may reach a larger audience with more willingness to deal with the problem if you use Google Translate or DeepL yourself and post in English instead of waiting to others bother to do the translation for you.
Maybe that way:
