Out of memory error
bbobbs
3-Newcomer
Out of memory error
I am using Mathcad 15.0 M050
I started getting an Out of memory error popup window, coming at random times when my MatchCAD file is open but not even running.
I added memory to my computer to increase its memory several times.
This did not reduce the occurrance of the Out of memory error at all.
Out of memory
VipulT
(To:bbobbs)
Hi @bbobbs,
Try to use a different user profile for login and see if the issue persists. With this it can be narrowed down whether the issue is system specific or user profile specific.
Vipul
VipulT
(To:bbobbs)
Hi @bbobbs,
Please share the dxdiag report of the system having issues with.
To get the DxDiag report: Click Windows Start button > type “DxDiag” in the Search box, and then press ENTER > Save all information to “DxDiag.txt
Also, are you saving the file locally or on a shared network location?
Vipul
VipulT
(To:bbobbs)
Hi @bbobbs,
Vipul
bbobbs
3-Newcomer
(To:VipulT)
Thanks!
