Outputting all program results
SamW
I've attached a Mathcad 14 sheet showing Mathcad's Find Solver function being used to solve three simultaneous equations, although I could solve them by substitution. I also use a simple program to give me answers for different cases.
I would now like to output results for all the different cases, and plot these on a graph. Is there a way to output results for each of the different cases simultaneously?
Sam
MikeArmstrong
(To:SamW)
Like the attached? I have called your solve block in the function.
I have also made your scripted component redundant.
I’m not sure what you the loads plotted against.
Mike
6 REPLIES 6
MikeArmstrong
(To:SamW)
Mike
Thanks Mike,
This is good. I tried to use a matrix with the solver but didn't manage to get it to work, hence the scripted function. This is better, so thank you.
Sam
MikeArmstrong
(To:SamW)
Thanks Mike,
No problem. Did you manage to get the graph sorted?
The iterating variable has to be passed to the Solve Block.
Mike
I am back on this again and do need to graph the results now. The problem is, I need to plot a line for each of the rows in the matrix below (against LC) This is a transpose of the answer in Mike's sheet that he attached in the earlier post, but I can't extract a single row from this matrix. I have tried a few different functions but am struggling.
Any help would be appreciated.
Many thanks,
Sam
SamW
(To:SamW)
I have managed to sort it by seperating then stacking the matrix as shown below.
VladimirN
(To:SamW)
Sam, hello!
Pictures that you attached to the messages are not visible .
