This could use a little clean-up to remove the cut-and-paste dependency in the symbolics, but I think this is about as much effort as I'm prepared to put into it.
Lovely work Richard, very nice.
Mike
Well, ringing in a bit late...dunno where some of you get the time 😉 I thought that I'd try a computational approach...though my first thought was to pursue the direction that Richard went in..and my solution has limited range, in a sense, because it /is/ computational, and not function-driven. I went on the assumption that I didn't know the answer, so I couldn't program a [hyperbola, for example]...
~R~
Nice answer Rich.
Two examples to document from one thread - good day ![]()
Mike
Thanks, Mike,
I don't have Mathcad handy, so can't look at the latest.
I recommend that we begin to adopt a naming convention such as this one
Parabola Problem rlm 1.0.M14.xmcd
where the base name help us keep track of the file, the initials help us distinguish twixt the submitters, the next number logs individual effort, and the Mxx tells us which version saved the file...this would minimize the filename duplication that we have now (3 files in this thread w virtually same name), and also keep the base name the same so that we know where to look for the file once we have downloaded it (one of the files w different base name)...'course, I'm really being self-serving here, because this old brain can't keep track of the details as it once might have... 😉
...and wrt my file, one can see that it has limitations...I forget how to blow it up, but it's not hard...neither would the fixes be, but I posted it as an approach, not a polished solution.
Hope that you all have a great Thanksgiving (for those of you who celebrate), and a geat weekend (for those who don't), sharing with family and friends. Safe journeys wherever you are 😉
~R~
Not my work, but thought I would share.
Mike
