sorting the values in a column in a long matrix
SLS
I am needing to sort the values from the columns in a matrix. I know you can use the csort function but that only sort one column at a time and leave the other columns unsorted. I need to sort all the columns at once from low to high. Any ideas.
Thanks.
ViktorKorobov
(To:SLS)
Look a picture.
Viktor
That should work. Thanks for the detail. You did anser my question.
MikeArmstrong
(To:SLS)
Have a look at the attached might be of some use.
Mike
