Pin and Pendulum
AlanStevens
Pin and Pendulum
Here's a problem I came across years ago. How many times does the damped pendulum hit the pin? Work it out using Mathcad or look at the video I'm about to upload and just count!
Alan
11 REPLIES 11
Fine!
But two question:
1. How many touches - 3 or 4?
2. Where is the file?
Sumbolic solutions of the Pendulum problem (Maple).
Jacobi sine
Sine (|angle|<7deg - sin a = a):
Valery Ochkov wrote:
Fine!
But two question:
For the answer to 2 - see attached.
For the answer to 1 - see attached!
Alan
Can you post here the file with a full description of the animation of the pendulum for this task?
AlanStevens wrote:
The video is at http://communities.ptc.com/videos/3320
Alan
One more task -
The thread is wound around the pin several times and then swings:
One more task -
The first step to this Math Model (an initial position of the Pendulum):
Ok Valery, see http://communities.ptc.com/videos/3326
But I'll leave you to extend the model to allow the pendulum string to lose tension!
Alan
Thanks!
But where is the file!?
Thanks!
See attached.
Alan
Sorry, better so:
