Please solve the calculation
ranto
Kindly solve the problem as per meow manual calc
12 REPLIES 12
-MFra-
(To:ranto)
Hi Robert,
if  P*RL = 1129 psi * in, even QL must have the same units. The algebraic csum  is made between homogeneous quantities.
Bye
Fred_Kohlhepp
23-Emerald I
(To:-MFra-)
psi*in = lbf/in
I agree completely. But the applicant has considered the mass and not the strength.
Fred_Kohlhepp
23-Emerald I
(To:-MFra-)
Since his example is dividing units out, and since if you correct lb to lbf the equation is unit consistant, I assumed that the omission was due to confusion on the part of a new Mathcad user.  At any rate, you defined Q as "psi in,"  I defined it as "lbf/in," and these are equivalent.
We'll have to wait for his clarification.  😉
ranto
(To:-MFra-)
Dear Sir,
Thank your for your immediate reply
But still now i didn't get the answer
Q as lb/in only not lbf/in
as i mentioned the value is correct.
-MFra-
(To:ranto)
by this I mean that P*RL and QL must be lbf / in.
Fred_Kohlhepp
23-Emerald I
(To:ranto)
Well, not quite
Dear Sir,
Thank you for your immediate reply.
Fred_Kohlhepp
23-Emerald I
(To:ranto)
Robert;
You're getting confused by the way Mathcad handles units.
There is a difference between lb and lbf; lb is a mass unit (like slugs and kilograms.)  lbf is a force (like Newtons.)  Your equations need to be unit balanced if they're correct.  Now, you define Q as two terms, the first term has defined units:
So Q has units of lbf/in.
When you write lbs/in of circumference, you're specifying force per unit length.  To Mathcad, that's lbf/in, or N/m, or . . .
‌Dear Sir,
Thank your for your reply
However i will check the units
Fred_Kohlhepp
23-Emerald I
(To:ranto)
My solution attached
Thank you boss
