I want to plot my values in Y-Axis such that the lowest stays in the upper and the maximum stays at the bottom without changing the sign. How can I do it? Thank you very much.
Faisal
That's not possible in Prime, but in (real) Mathcad (15 and before) it is possible without problems by changing the axis limits accordingly.
You can do it in Prime but you would have to use the new chart component which was introduced with Prime 5. by defining Ymin and Ymax accordingly.
Unfortunately this chart component otherwise is just a piece of crap.
May be so
But the OP did not want to change the sign...
@LucMeekes wrote:
But the OP did not want to change the sign…
Sori, Ai nou Inglish veri plokho!
Thank you everyone for your help
