Hello!
My question is: Why can't I plot the function f(t) by typing it in Y-axis area?
The only way to plot it is to type the equation value of the function itself.
What I want is this:
Best regards,
Sergey Dukman
You should attach the worksheet, and state which version of Prime you are using.
Because you typed the t in the placeholder for the unit.
Place
f(t)
before the placeholder.
Same for the ordinate, be sure to set the t in the placeholder before the placeholder of the unit.
Place
f(t)
I have got this. Thank you.
By some reason I wasn't able to upload the Mathcad sheet.
Sergey
There's a problem with the forum. If you .zip your file, you can attach the .zip file.
