Do You know it?
Valery Ochkov wrote:
Do You know it?
Unfortunately, yes! The effect was there in Prime 2 as well - the limit was even lower there, though.
Primes plot has three limits: 4999, 49999 and 500001.
The other limits were found by experience and I just confirmed they are there in Prime 3. The help succinctly states "However, full formatting is available up to 5000 points." I have moaned about it one or two times in the forum - to no avail as it seems.
Bad limitations, indeed.
And what about sizes of files?
Honestly, I won't care. We don't know what exactly the program stores and how, so we can't tell and estimate the file size. You probably expected the size to be tenfold while it showed to be nearly the 40fold. Another PTC magic of the black kind, I guess 😉
Thanks!
I have this phenomenon (large file size) encountered when trying to place Prime sheets on the PlanetPTC.
No message about ladge file and no effect...
As already written, I do not know the internals of the Prime file format, so the following is pure speculation.
Prime seems to save the last calculated state of the sheet and so it also saves the plots.
If it saves the plots in some kind of bitmap format, a linear change to the tenfold would result in a bitmap wich is 100fold. If saved using some compressed format could explain the increase of your file to the 37fold. Again - thats pure speculation.
In Mathcad 15 we could make files significantly smaller by putting calculations and graphs in collapsed regions. I didn't test if this still applys to Prime.
BTW, does anyone else miss the opportunity in Prime to close an opened region at its end, not just at the top. Woul be convenient if we could have that feature back.
