Plotting local max-min-points ?
lvl107
20-Turquoise
  Hello Everyone.
           Thanks in advance.
(To:lvl107)
@lvl107 wrote:
Could you attach *.xmcd ? ( I'm afraid I may hit wrong key stroke... )
    Best Regards.
Hmm, really!??
Here's a slightly different approach:
Unfortunately the more direct and logical
does not work in Mathcad - muPad is not capable to find the solutions.
9 REPLIES 9
Set a function that is the derivative of f(x).
Use the root function on this derivative within a range to determine unique roots.
You now have enough info to plot the points.
lvl107
20-Turquoise
(To:ValeryOchkov)
Many thanks both of you, Valery.Smiley HappySmiley HappySmiley Happy And I still have a query : "How to prove what point is local min-point ?
Best Regards.
(To:lvl107)
lvl107
20-Turquoise
(To:Werner_E)
    Best Regards.
Fred_Kohlhepp
23-Emerald I
(To:lvl107)
AWWW!  C'mon!
(To:lvl107)
    Best Regards.
Hmm, really!??
Fred_Kohlhepp
23-Emerald I
(To:lvl107)
Some basic calculus (see Werner's application):
  • First derivatives of a function are zero at inflection points (maxima/minima),
  • The sign of the second derivative at the inflection point indicates minima (second derivative positive) or maxima (second derivative negative.)
(To:lvl107)
In case of this function Mathcads symbolics is capable enough to give you al solutions, so you should use it.
If your goal is to limit the results to x1<x<x2 you may use the "assume" modifier.
