Polynomial, yes or not?
  • September 4, 2019
  • 3 replies
  • 5905 views
Hello everyone,
I would like to create a Mathcad program that distinguishes whether the denominator of a given fraction is a polynomial or not, returning 0 or 1 for example. How do I do this?
Thank you.
Examples please.
Note sin (x) generally isn't viewed as a polynomial in x. But it can be written as such.
-MFra-21-Topaz IIAuthor
The function of the program should be something like this:
once the type has been identified, we pass to the transformation into a polynomial, if possible.
I got this far, so far:
I doubt whether this will (rather sure that this will not) work in Mathcad 15, but it does work in Mathcad 11.
Mathcad 15 returns this error:
I am tempted to say that what you demand can't be done in Mathcad in a reasonable way as Mathcad does not provide the necessary tools.
Nonetheless here is a first attempt which may serve as a starting point for your own experiments.
There are a lot of drawbacks so far - you can only evaluate the function symbolically, its only working for functions in one variable and otherwise constants, ...
A few of the adverse effects could probably be corrected by some further investigations, but presumably not all. And I guess it will remain an uncertain, unreliable thing.
it would be better if the circled functions are not considered an error by mathcad. How to do?
I don't think there is a way.
You can switch off signalling of certain (types of) warnings.
You cannot switch off errors.
