Possible Vector Output Error with a function
jroth
I'm wondering if this is a ligitimate error, or if there is something I may be missing. In the sheet you can see that I was trying to get a vector output from a vector input. If the expression is factored, is it possible that this will not work?
Please see the attached sheet.
(To:jroth)
It not an error at all. The expressions in both parantheses are vectors and so their product is calculated as scalar product.
To avoid this, Mathcad offers the Vectorize operator - look it up in the help.
(To:jroth)
jroth
(To:Werner_E)
Thank you again for your help Werner, it has been much appreciated. I was not aware of the vectorize operator.
