Please guide to prepare the plot as per the attached files
Enclosed is Prime worksheet that does the plot:
Cheers
Terry
I don't think that the chart component is available in Prime 3.1 (used by ranto as per the posting subject)
Thanks Werner did not notice that bit.
American Petroleum Institute (API) means company can likely afford to upgrade to the latest version?
Have included a postscript so the workings are shown. The actual plot bit is easy.
Cheers
Terry
Would this do?
Prime 3.1 file attached.
The prime 6 file alos i had added in prime 3.1. and it is working the same graph in prime 6
Thanks a lot to all
