Prime 7 chart component issues
Raiko
Hi folks,
so far I've noticed a few issues with Prime 7.
  • The combo box doesn't accept exponents when defining values
  • I doesn't also allow the unit for thermal expansion coefficient (1/K). It is not read in properly as it is considered a formula.
However, the chart tools
  • only when changing the line character from solid to dotted it is properly displayed in the legend.
  • you can't define units such as µV on the axis so the workaround is to copy and paste the µ from the character map.
  • what irks me most is that logarithmic scaling is not displayed properly. The numbers on the axis are correct, but the axis representation is not. See attached images.
  • has any body figured out how to change the steps on the logarithmic axis? It appears to be fixed.
Raiko
ttokoro
20-Turquoise
(To:Raiko)
