How can i use programming to plot a linear or exponential rise and decay as shown attachment with red mark. Only for areas marked in Red
Jacob
I can't do programming in Prime, so here's a solution without programming.
But I'm sure you can turn that into a program.
Success
Success
Thank you for the help
10^-6 and 10^-7 are tau of A*exp(-t/tau).
Thank you for the details for realizing exponential plot
t is in second unit such as 0.000000001 s.
@ttokoro ......I run to trouble in inserting the function s linear(cant find in insert functions) and with exp there is a syntax error i cant figure out. Can you share your worksheet or give some tips
See the attached file. I make functions by programming because the subject is Programming.
Awesome...thank you
