Problem with money
bgarmann
Problem with money
I have a problem with this sheet.
I am trying to multiply an add some things with each other. But i get a error.
Can you guys help me ?
VladimirN
(To:bgarmann)
The variant of the solution in an attachment will suit you?
8 REPLIES 8
(To:bgarmann)
The error message is quite informative, I think.
You multiply two variables of unit "Money" and so you get a variable of unit "Money"squared, whatever that may be. You see the €² in your screenshot?
Then you try to add simple "Money" to that "Monay²" - this has to fail.
Think of meter.
Can you add 2 m² + 3 m ? Sure not - you can not add an area and a length. What should the outcome be?
The same applies to € + €² - they are not compatible and Prime correctly refuses to add them.
WE
StuartBruff
23-Emerald V
(To:Werner_E)
Think of meter.
WE
So, it's true.  Money really is the square root of all €vil?
Stuart
"So, it's true.  Money really is the square root of all €vil?"
Oh, That's POOR!  🙂
(To:StuartBruff)
Concerning the €uro you are not far from the sad truth, I guess 😞
nas0k
(To:StuartBruff)
I have a problem with money too - I would like to have more then I have
VladimirN
(To:bgarmann)
Thanks for the update. It's working fine now
