Problems opening a Mathcad Prime 3.0 File
mfochs
7-Bedrock
I was trying to do some basic calculations for the cooling cycle. Multiplication/addition/division/etc. with some variables I set. Turned off computer and when I went back to continue I get this error:
The file type is not supported.
Log file is located at: c:\ProgramData\PTC\Mathcad Prime\Logs\Mathcad Prime_Exception_20150407_164625.log
I was wondering if there is any way to get back at the file without having to start over from the beginning. Attached is the mathcad file I was attempting to open and the Log file referenced in the error.
mfochs
7-Bedrock
(To:mfochs)
Nevermind, just started over.
mfochs
7-Bedrock
(To:mfochs)
ryankelley
(To:mfochs)
I've moved this discussion into our Mathcad community in case there is any follow up and you need some additional advise from our members here.
