Summation
lmartinez
7-Bedrock
Summation
How can I put the correct summation in my formula ? If you will see D seen undefined.
With attached Mathcad Prime ..
You define a dimension D at the top of the sheet, so your table doesn't define. Change the name in your table (and keep your vector indices straight, and all works out!)
I did not notice that I defined D twice, Now my spreadsheet are working right. Thank you.
